Vertex K8400 extruder feed
Posted: Tue Jan 02, 2018 2:42 am
Hello
I did now my first print with Simplify3d on my K8400....
I've read in some places that the extruder feed is wrong in the original Velleman firmware with 200 steps/mm...so I reduced it to around 145 steps/mm...
What extruder feeds are other users using here with Simplify?
Do you also have effects like inner layers are not connected to outer layers and there not having a clean surface?
Seems also that the first layer is printed with 0.09mm with default settings whereas Vellemans software is using 0.2mm.
