PETG Material
Posted: Tue Feb 06, 2018 3:53 pm
Hello,
I am fairly new to S3D and have been using PLA and my Robo3D R2 printer with a PEI sheet now successfully. However, now I need to print with PETG and support recommended that the "best place to start would be with the ABS profile, then Click the Green + to add a new Material that you can call PETG. You can then check the PETG section of the Materials Guide for help on getting the settings dialed in."
I started by changing the bed temp to 85 and extruder to 240 and turned the fan on to 100% on layer 2 and up like I have with PLA. However, what other settings have folks out there changed when using the ABS profile as a starting point for PETG? I see the Materials Guide talks about changing retraction settings to reduce stringing and dealing with blobs and zits, but what values have each tried, or is this so specific to the printer that I should ask someone in a Robo forum on this?
Thanks!
Thanks!
