Hi Guys,
I have a part that is particularly challenging for me to print because it requires a LOT of supports inside just to hold up the top. Lets say this is 160mm in diamater and 80mm high with 1mm thick walls. Everything else is hollow. Think of this like a hollow soup can sliced in half vertically.
As I print the base and walls the print is perfect. No issues at all. Then when I get to the top it goes very badly. I'm exploring options for printer settings to try to overcome this issue but it's a pretty big challenge.
I thought about flipping the part on the printer 90 degrees on the X axis so the two points were on the printer base but I would get degraded results in the walls and also loose the nice smooth bottom and top. I would also need to use a large raft (wasted material) just to secure the object to the print platform. So I would certainly prefer to print it in normal orientation from the bottom up.
The only viable option I see is printing pillar supports all the way from the bottom to the top on the inside. Then I have a tedious job of removing all that stuff. Or printing the object in 2 halves (each 40mm high) then gluing them together. But that really sucks.
So I'm exploring options and reaching out to the experts to see what you would do in this case? I am just doing normal PLA for my material.
I have attached the STL file for you to examine the object. Please don't waste resources printing it ...This is just a test part to illustrate the challenge I face. I'm simply trying to explore options.
