Hi dkightley,
You have a Prusa i3....yet the machine in the profile is a Makerbot Replicator and the firmware is Reprap. ..which I'm not sure is the right one or not
I don't know where you saw that Markerbot Replicator machine profile.
The firmware is RepRap(Marlin/Repetier/Sprinter), I have Marlin.
The machine illustration in preview is also a Makerbot...and the model is way off the bed!
I don't understand this. I have my build volume set to 200, 200, 195. And my model is in 90, 90, 0. I think it's perfectly fine.
The extrusion multiplier is 2.5....which is way off what it should be.
I have my extruder steps/mm in 93.0, I think that value only multiplies the 93, I will change the value in Configuration.h and go back to 1 in extrusion multiplier.
The primary extruder AND heated bed are both set to the T0 identifier....which I'm not sure is right.
I really don't know about this, I never have a problem. What you to recommend ?
There's virtually nothing in your starting script...no temperature setting, etc
The starting script have G28 (home) and G29 (autolevel), why should I put temperature settings in there if it's automatically match with the values in the Temperature tab ?
The new extruder may be loose...or you've now got a slack belt
I will buy a new belt and try again.
Thank you for your feedback, I appreciate it.
