Page 1 of 2
Flashforge Guider II Profile
Posted: Tue Mar 06, 2018 5:23 pm
by dcousins
Hi Simplify3d
Just wanting to know has anyone had any success using Simplify3d with the Flashforge Guider II?
I have tried creating a profile through both config assistant and customising existing Flashforge profiles to no avail.
Would love to get my hands on a profile someone has had some success with using a Guider II??
Thanks in advance!
Re: Flashforge Guider II Profile
Posted: Wed Mar 07, 2018 7:11 am
by wirlybird
Yes, I can send some specifics this evening. I just started with a blank/generic profile and set it up as I needed.
Make sure you are on the latest firmware or at least one back. I think the newest one may have an issue I need to check out.
If you aren't using it then try out Flashprint. It does a great job with the Guider II and the tree supports are the bomb once you get used to them!
Posted: Sun Mar 11, 2018 10:04 pm
by dcousins
Thank you for the response wirlybird!
I will check my firmware version as I am still on stock.
I was going to try Flashprint as a last resort if I couldnt get S3D working. Currently I use S3D with a Flashforge Creator Pro with my classes and we have been making steady progress learning the software. Would really like to be able to use S3D with both printers.
Any chance I could get you to send me a copy of your profile wirlybird?
Cheers!
Posted: Thu Mar 29, 2018 7:41 am
by wirlybird
Sorry not to get back sooner. How's it going with the Guider II?
Posted: Wed May 09, 2018 2:21 am
by bchs
I am having a similar problem,
I have a Guider II, and it does not wait for the extruder to heat up to the set temperature, and just starts printing.
Any profiles people could share or settings to add/change?
Posted: Wed May 09, 2018 8:45 am
by wirlybird
I'll try to remember to post mine.
Posted: Thu May 10, 2018 7:48 am
by wirlybird
bchs wrote: ↑Wed May 09, 2018 2:21 am
Have you check on the temp tab to see that the option to wait for temps to stabilize is "checked" for each temp set?
Posted: Wed Jun 13, 2018 11:01 am
by jorren624
Wirlybird - Would you be so kind as to post your S3D profile for the Guider II ? We are having similar issues getting them to interact properly.
Thanks!
Posted: Mon Jul 23, 2018 6:33 pm
by jasonraz
Bump..
@Wirlybird, seeking same profile, having strange issues with S3D and Guider II.
If I print from S3D printer tells me The nozzle will hit the print bed. Print from Flash Print no issues.
Posted: Tue Aug 28, 2018 10:24 am
by S3D-Jake
viewtopic.php?f=9&t=10769&p=43747#p43751 :
you may contact Simplify3D's support staff for a profile that works well with the Guider II.
