I've been wrestling with the titan extruder (Bowden setup, 750mm bowden tube) skipping regularly during infill printing but everything else on the print, coming out just fine.
Default Print speed: 60mm/s
Outline %: 70%
Solid Infill %: 80%
Since the outline prints fine at 42mm/s (60mm/s * 0.7), and Solid is fine as well at 48mm/s (60mm/s * 0.8), I've been dropping the default print speed and correspondingly boosting the Outline % and Solid % to keep the rates at 42mm/s and 48mm/s respectively.
Just wondering if anyone has a logic check on that approach or other suggestions. Printing PLA at 210 or so.
I'm getting down to 40mm/s for default and then 100+% for Outline and 120% for solid.
Goal is to not have the titan hobbed bolt caked with filament on long prints.
