dawjr
Initial Layer Horizontal Expansion
Wed Apr 04, 2018 5:17 pm
Hey, Guys. Still learning S3D capabilities. One parameter I miss from using Cura is "first layer horizontal expansion" found under the "shell" menu. This applies an offset (either negative or positive) to the first layer - it effectively eliminates "elephant's foot" - that is the ridge at the bottom of the part from the first layer squishing out.
Is there a workaround in S3D that anyone knows of?
All the best, Don
rrdavis
Re: Initial Layer Horizontal Expansion
Thu Apr 05, 2018 7:05 am
Go to Tools > Variable Settings Wizard, and then you can setup different settings for the first few layers if needed. Just add a split location right above the first few initial layers then edit the "horizontal size compensation" setting on the Other tab for that process.
Thu Apr 05, 2018 7:34 am
I would also suggest to read up on the causes of elephants foot and try to eliminate or at least reduce it that way.
Is the nozzle a bit too close to the bed?
Is the first layer too thick or being squished to much?
Is the bed too hot for the material and too hot after the first layer?
tonyno
Thu Apr 05, 2018 7:59 am
S3D calls that Horizontal Size Compensation. It's on the Other tab of Process settings. I use -0.4mm for the first layer.
Thu Apr 05, 2018 8:20 am
Never used it but can you set it per layer or just make a separate process for the first layer?
tonyno
Thu Apr 05, 2018 4:16 pm
Yep. This was from when I was printing at a 0.4mm layer height.
dawjr
Fri Apr 06, 2018 12:22 pm
Thanks so much for the input, Guys. I look forward to trying it out.
All the best, Don
ClintGoss1
Thu Apr 12, 2018 3:10 am
Process => Other => Horizontal Size Compensation looks like it will address my current issue ... however ...
It's in mm and I think that I need it in percent ... my XY dimensional issue grows proportionally to the size of the model.
Any ideas?
-- Clint Goss
Thu Apr 12, 2018 6:51 am
Any ideas?
First thing is, I would think it is in an actual size or dimensional measurement because that is the purpose, to resize by a specific amount.
I think when you enter a size it is applied on X and Y.
A "percent" might be a good option though.
Thu Apr 12, 2018 7:26 am
Okay....let's think about this...Horizontal Size Compensation in mm or %age??
You print an object....and you find the holes are a bit tight and the overall size is say 2mm too big. You want to resize the object by reducing its size by 2mm.
Value by mm: Divide2 by 2 = 1.0 Enter value.
Value by percentage: . Measure size of object...its 256mm 2.0 as a percentage of 256...get calculator... 0.78%. Enter value.
Which would you really want to use??? Think about it! Now take your blinkers off....and think about it again as something ALL users would want!
