SPEED
single outline corkscrew printing mode does not work
Fri Sep 06, 2019 8:28 am
I'm trying to print a single perimeter square and the single outline corkscrew printing mode does not work
It still keeps printing one layer clockwise the other layer counterclockwise
I didn't try to print it but i can clearly see it on the preview mode
Re: single outline corkscrew printing mode does not work
Fri Sep 06, 2019 11:51 am
Have a read of my post on this thread: viewtopic.php?f=9&t=13442&p=51350&hilit=vase#p51350
It will explain where you are going wrong.
SPEED
Fri Sep 06, 2019 3:19 pm
How do you assume my model is not printable ?
I'm not an idiot.
Overheal
Fri Sep 06, 2019 3:30 pm
Can you post the factory file so we can take a look please
Fri Sep 06, 2019 3:47 pm
I'm not an idiot.
I don't.....and I'm glad you're not! ;)
Nuf said from me....
SPEED
Fri Sep 06, 2019 7:43 pm
Like i said it's a square with 1 perimeter can't get any simpler than that but here it is.
Ended up adding 1 more perimeter because not even Cura could print it right...
That's the version with the 2 perimeters since i overwritten the 1 layer version still corkscrew dosn't work as it should tho (1 direction)
apomonosh.factory
(101.8 KiB) Downloaded 12 times
apomonosh.stl
(447.64 KiB) Downloaded 15 times
Sun Sep 08, 2019 3:41 am
I'm not an idiot.
You are sure?
It will be, but not as a hollow body with a definide wall width. Your model has 2 walls, an outer and an inner one. How you want to print it with onle one perimeter?
Sir, you havn't understood anything! Go back to Cura, they have more and good automatism than S3D. Here you must invest more than pressing a knob.
GER
SPEED
Tue Sep 10, 2019 4:41 pm
I'm not an idiot.
You are sure?
GER
Like i said i am not an idiot.
You are the one who hasn't understand anything.
It doesn't matter how many perimeters your model has corkscrew will always print it with one perimeter. That's it's function.
It's just sad that people so ignorant on 3dprinting try to teach others.
Wed Sep 11, 2019 7:13 am
I'm not an idiot.
You are sure?
GER
So insulting the people who are trying to help by explaining the issue to you is how you go about getting help?
Maybe try dropping the attitude and listen to what has been expalined. You have been given the solution.
Good luck with it.
