[FIXED] multiple processes leading to 2 layers at same z, z skip, and skipped support material
Posted: Thu May 17, 2018 5:17 am
So I am currently encountering an issue where when I go from one process to the next it prints two different layers at the same z (as can be seen in the attached compressed photos for layer 6-layer 7, as well as layer 68-69 and 80-81) this behavior did not occur between layer 46 and layer 47, however that process change causes several skipped support layers (there should have been support in layer 48) as well as an apparent skipped layer between layer 47 and 48 (the layer height in that process is .1, but the change between 47 and 48 is .2). Here is a list of the relevant settings that were varied between each process change. I have checked and my installed version of S3D is 4.0.1, I actually just re-installed it today.
process 1 (layer 1-6)
layer height-.2
primary extruder- right
prime pillar- yes
support- every layer
infill- every layer
stop printing- .4 mm
process 2 (layer 7-46)
layer height .2
primary extruder- left
prime pillar- yes
infill- every layer
start printing- .4 mm
stop printing- 8.4 mm
process 3 (layer 47-68)
layer height- .1
prime pillar- yes
support- every other layer
infill- every other layer
start printing-8.4 mm
stop printing-10.6 mm
process 4 (layer 69-80)
layer height-.2
prime pillar- yes
infill- every layer
start printing- 10.6 mm
stop printing- 13 mm
process 5 (layer 81-150)
layer height-.2
prime pillar- no
support- irrelevant
infill- every layer
start printing 13 mm
layer height-.2
prime pillar- yes
infill- every layer
layer height .2
prime pillar- yes
infill- every layer
layer height- .1
prime pillar- yes
layer height-.2
prime pillar- yes
infill- every layer
layer height-.2
prime pillar- no
support- irrelevant
infill- every layer
