Hello, I have got massive problems with my hypercube using simplify3D.
First of all, it's for sure my fault, not Simplify3D's but I don't know how to fix these problems myself.
Build:
300x300x500 mm, for testing reasons only 200x200x200 mm are enabled.
Mainboard: Duet3D wifi
Material: 1.75 mm PLA at 200 degrees
Extruder: Bowden (60cm), E3D clone with Nema17
Circuits: 24 V for the electronics, 12 V for the fans
Heatbed: 500 W regulated by mosfet
Frame: 3030 Aluminium extrusion
Printing platform: Selfmade, from bottom to top: Heatbed, 5mm aluminium plate, carbon fiber plate 2 mm, bluetape
Bed-Probe: IR Sensor by DC42
My problems are:
Bowden extruder: As soon as a print is started (after the first layer), the PLA seems to be stuck in the hotend. While pushing filament through the disconnected PTFE-Tube or through the heated nozzle with no print started, it works flawlessly. This problem leads to a massive underextrusion while printing but only occurs after the first (few) layer(s).
Height of the nozzle: Even tough I'm using the DC42 IR probe, printing the first layer is not smooth. I have to adjust the Z-height by Z-Baby-Stepping often while printing...
Speed: The printing head does not accelerate smooth. At the start of a movement it's very very slow which leads to an overextrusion while executing small movements. (if there's enough PLA extruded...)
Extruder-motor: There are often squeezing noises coming from the gear while printing (at these moments when it seems that the hotend is clogged while printing). But as soon as the PTFE-Tube is removed from the hotend everything works just fine... The length of the extruded PLA through the disconnected PTFE-Tube was also measured and is correctly as expected.
I hope that you have some ideas what could technically be causing these problems. Because my knowledge ends here and I can't fix it myself. I don't know if I set up the Duet, the IR probe or simplify3d wrong or all of them..? Also bed probing is slow. (or at least the movements of the print head including the z-axis movement). How could this be accelerated?
Thanks for anyone reading this and trying to help me
Attached: Simplify3D factory file, config.g, bed.g
