Fizbane
First Layer Gaps Poor Quality
Sun Jul 15, 2018 1:46 pm
I am at a loss for why my CR-10S has problems with the 1st layer of prints. After the 1st layer the overall quality is good even excellent on some prints but the 1st layer is stringy and does not seem to stick to the rest of the print. What really throws me off here is the bed adhesion is rock solid.
I have attached photos of the issue and then the quality past the 1st layer or so.
Any help would be appreciated thanks.
-Sean
brunofporto
Re: First Layer Gaps Poor Quality
Mon Jul 16, 2018 3:02 pm
I am having this issues too... This made me go back to slic3r PE......... Following :D
Mon Jul 16, 2018 3:58 pm
This is symptomatic of the first layer being printed a little too high above the bed.
What you need to do is to prepare a small test piece (to save plastic & time) and adjust the globalZ field (on the gcode tab) by a negative amount....it can go negative! Adjust by half a layer thickness...and try a print. Look at the finish of the bottom and adjust again if reqd...etc.
The bottom of the part should be flat and smooth and not show the separate extrusions....but should also not squish the layer so it forms what is termed an "elephants foot"
brunofporto
Mon Jul 16, 2018 4:19 pm
I have this issue even with heavily squished first layer and no issue at all with Slic3r for the same printer and settings.
Not sure what settings I changed at Simplify3D to start it.... One day I did not had it and after tweaking several settings it started to happens at all my profiles. Even recovering old backups did not solve the issue and it made me go back to Slic3r PE
Edit: I was going to test to show the issue here but.... The issue is gone....
airscapes
Mon Jul 16, 2018 4:54 pm
starting height, filament diameter (measure it, it is not always 1.75 ) and extrusion multiplier all need to be correct.
I have attached a small 2 layer stl
26x26x.4 2 layers at .2.stl
(684 Bytes) Downloaded 64 times
Fizbane
Wed Jul 18, 2018 10:30 am
Appreciate the responses. I verified the diameter of the filament and the extrusion where all good it appears that a small adjustment to the starting height may have done the trick in the end.
Printing out another larger model to verify as it past with flying colors using the 2 layer sample Airscapes posted.
-Sean
