DoctorRudd
Gcode problem with Prusa i3 MK2.5
Wed Sep 12, 2018 5:43 am
Hello,
with SLIC3R_PE I use the following startcodes for temperature setting:
M104 S110; Extruder to 110
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S110 ; wait for extruder temp to hit 110
M104 S[first_layer_temperature] ; set extruder temp
In S3D, the variables are not read out. I also tried e.g. "M190 S$", but the bed stays cold.
What am I doing wrong?
Thanks for your help, Peter
Re: Gcode problem with Prusa i3 MK2.5
Wed Sep 12, 2018 4:43 pm
The variables such as first_layer_bed_temperature are variables that Slickr make available in scripts. S3D has its own set of variables...see this thread for what they are and where they can be used: viewtopic.php?f=8&t=1959
Thu Sep 13, 2018 7:00 am
Use the included profile for the MK2(s) and look a the start script to see how it is constructed. Or use the one for the MK3 and look at its start script.
Using one from Slicer will not function as you might expect it to.
cybrsage
Fri Sep 21, 2018 3:17 pm
Also make sure you downloaded (manually - the update feature does not work for it) the latest update. It still hsows as 4.0 on the website, but it is actualyl 4.0.1.
DoctorRudd
Sat Sep 22, 2018 3:22 pm
Thank you all. I could manage to get it working,
Best regards, Peter
