I recently purchased a used Trinus and running it via simplify3d the results are stunning
However I am relatively new to Simplify3d and I might be misunderstanding the control panel
If I select print with the micro sd card in my laptop it runs perfectly
However I wish to disconnect my laptop or at least not leaved it switched permanently on
If I put the SD card into the slot in the Trinus mother board and select print from sd card with code ie signet-12.gcode it will not run
replace the name with auto0.g and put it in the motherboard , it does not auto run but when selected via control panel, print from sd card it does run
heres my issue I will eventually have about 800 signet rings , multiple shapes and multiple finger sizes .
I do not have the lcd screen, and it seems they are no longer available , can anyone advise me on a workaround please
