Hello,
I would like to print a cover for a ceiling lamp electrical interface to hide the loose isolated contacts from view. I made a model of a hollow half-sphere with a 10 mm flat ring to use double-sided glue tape to fasten it to the ceiling. As it turns out, Simplify3D doesn't seem to generate any kind of support for the middle part of the sphere. A hole opens and the print is ruined. I tried kinda all things that seemed possible, but the supports are not generated. Is that possibly a bug? I can send the model if that helps analyzing the issue. I use a raft.
