kurtnelle
Where is the option for sequential printing?
Thu Nov 08, 2018 11:23 pm
martin1454
Re: Where is the option for sequential printing?
Fri Nov 09, 2018 1:23 am
Add 2 procceses and assign each to one model, then when you press print, you get a window where you can select sequential.
kurtnelle
Fri Nov 09, 2018 11:58 am
Ok, I found the option thanks.
The preview doesn't show multiple parts being built one by one though. I changed the clearance on the parts to 100 mm and it still didn't work. It either shows all being made or just one being made. Does the preview actually show the order of the build?
kurtnelle
Sun Nov 11, 2018 9:37 am
You have to select all the processes before pressing prepare. Goodness.
jmdearras
Mon Nov 12, 2018 9:08 am
sequential printing is broken in 4.1
