dragonn
[FIXED] jerky movment on internal single extrusion
Sat Nov 10, 2018 9:23 am
On 4.1 my printer is doing really jerky movements when doing internal single extrusion, this causes my extuder to even loses steps. On 4.0 everything runs fine. Interesting is that the 4.1 gcode is much bigger then 4.0.
I attached factory file and both g-code files. Both file a sliced at exactly the same settings.
4.1.gcode
(744.7 KiB) Downloaded 53 times
4.0.gcode
(108.45 KiB) Downloaded 48 times
jerky.factory
(3.36 KiB) Downloaded 52 times
dragonn
Re: [4.1] jerky movment on internal single extrusion
Fri Nov 16, 2018 4:34 pm
Any update? Confirmed?
Wed Dec 12, 2018 2:43 pm
I’m happy to state that this issue with internal single extrusions should be resolved now in the latest 4.1.1 release. Our team successfully tested your jerky factory file presenting this issue in 4.1.0. As you can see in the visualization comparison posted below, 4.1.0 creates a much improved smooth corner effect when compared to 4.1.0. This was just one of many improvements to the software. All of which are detailed on our Release Notes page.
