Problems with 4.1, now reverting to 4.01
Posted: Sat Nov 10, 2018 6:53 pm
by ashleyfoxcroft
Using same models and print settings between 4.01 and 4.1, there are very noticeable gaps between the start and finish points of outlines/perimeters; there looks to be insufficient extrusion at the beginning of a line. I tried to compensate by reducing retraction & adding extra retraction distance or turning off retraction, but after several attempts (and half a day), the issue persisted. I then printed the same model. using same settings but generated by 4.01 and the problem went away. I then used Cura to slice the model using similar settings and there was no problem so I don't think my Printer or Filament was to blame.
Re: Problems with 4.1, now reverting to 4.01
Posted: Wed Nov 14, 2018 5:19 am
by mzakelj
Hm, where did you get older version. I have licence but i dont find the old version. It would be nice if we can acces older versions.
