Printer never starts printing, but shows "Print Complete"
Posted: Thu Nov 15, 2018 10:01 am
by nbarrera2@angelo.edu
I am currently using a Makergear M2, with the new simplify 3D 4.1. The bed and extruder both heat up. At first, the print would start too far from the bed, so I went into the edit process settings to fix it. No matter how much I changed the height of the bed, the print always started printing from the same height.
I switch the print, thinking that might've been the problem. Now the printer doesn't start printing at all, but shows the "Print Complete" tab when I press the print from USB button.
Re: Printer never starts printing, but shows "Print Complete"
Posted: Tue Nov 20, 2018 5:27 pm
by TomOH
I have the same problem with 4.1 and an Anycubic I3 Mega.
If you go into the control panel (ctrl + p) first and connect the printer manually, it should work. If not, restart the printer and try connecting again. Definitely another bug in 4.1...
