BrandonJSpangler
Dremel 3D20 Connectivity Issues - After Print
Fri Nov 23, 2018 10:06 pm
Hello Everyone!
I am new to 3D printing and also to Simplify3D, so I wanted to post my issue on here so that I can hopefully get some guidance. I am able to connect my 3D20 via USB and print from Simplify3D successfully one time. However, after I print anything, it seems like the software is losing connection to my printer.
Basically, if I want to print an item more than once, I need to completely shut the software down and restart in order to connect to my machine again. Without doing this, it seems to hang in a perpetual state of "printing" but isn't doing anything. I have tried going into some of the settings within the "machine control panel" but haven't had any luck getting it to connect again after forcing a disconnect. It's not a major issue, but it is a minor nuisance that I have to constantly shut the software down and restart when I am making a number of small prints...
Any thoughts?
Thanks!
Frezzno
Re: Dremel 3D20 Connectivity Issues - After Print
Mon Dec 31, 2018 11:08 am
Yap, I have the same issue. Also I have updated to latest firmware 20180611.
Thu Jan 10, 2019 12:37 pm
Thanks for your help reporting this issue, everyone! Can you please let me know which OS you're using, the current firmware version in use, as well as if this is an issue for your current firmware in the Dremel's default software on that firmware?
I'll be using this information to see if we can reproduce the error in our office with our own 3D20!
Thanks again for your help!
