nuggetz
Weird support issue
Tue Nov 27, 2018 9:22 am
I just generated some supports and the placement before slicing looked ok but check out the result.
dragonn
Re: Weird support issue
Tue Nov 27, 2018 9:25 am
Your model is probably broken, try repairing it with for example netfab.
nuggetz
Tue Nov 27, 2018 9:50 am
3D Builder in windows didn't find any issues. Slices ok as is in Slic3r.
dragonn
Tue Nov 27, 2018 12:48 pm
Can you post the STL file and factory file?
Tue Nov 27, 2018 2:13 pm
PS the factory file will contain the stl file.....so you don't need both!
And by factory file, I mean the file with the .factory suffix...…..not the profile file, which has .fff as its suffix.
nuggetz
Tue Nov 27, 2018 11:49 pm
Here you go
support.factory
(972.36 KiB) Downloaded 52 times
Wed Nov 28, 2018 5:19 am
Try the attached. Shape file repaired using 3D Builder.
When using 3D Builder, you need to "Import" the shape to kick in the checking.
Dial_Back_A_v2_conduit-post.3mf
(212.36 KiB) Downloaded 29 times
