Strange Line Patterns
Posted: Thu Nov 29, 2018 8:35 am
by Peter_O
Printing with 5 wall lines, I get these rectangular artifacts on the lower rim layers. (1st picture)
On the smaller top layers all lines run the full circle. (2nd picture)
Any Idea how I can avoid this?
Re: Strange Line Patterns
Posted: Thu Nov 29, 2018 11:34 am
by Raise3D Pro Plus 2
Show me your values of Layer tab...
Posted: Thu Nov 29, 2018 11:51 am
by Peter_O
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,4
; bottomSolidLayers,4
; perimeterOutlines,5
; printPerimetersInsideOut,1
; startPointOption,3
; startPointOriginX,0
; startPointOriginY,0
; sequentialIslands,0
; spiralVaseMode,0
; firstLayerHeightPercentage,120
; firstLayerWidthPercentage,100
; firstLayerUnderspeed,0.5
Posted: Thu Nov 29, 2018 1:29 pm
by S3D-Alex
Could you please post a Factory File for this? The settings are helpful but their interaction with the model file is important for things like this.
Posted: Thu Nov 29, 2018 2:06 pm
by Peter_O
Here's the .factory and the .stl.
Posted: Thu Nov 29, 2018 2:21 pm
Some issues in STL file. Gaps probably. If you use advanced tab and you change parameters in Thin Wall Behavior everything change is better. But also not perfect.
Posted: Thu Nov 29, 2018 2:31 pm
by dragonn
Yeah, they are separated bodies in the STL:
A proper printable STL file should have only one body (expect doing some multimaterial/multicolor print)
Posted: Thu Nov 29, 2018 2:33 pm
It should be composite part in STL file. Try to change it from CAD software. It should help. Or you can use some STL repair www site.
Posted: Thu Nov 29, 2018 5:13 pm
Here you go......a repaired and slicable part!
I would recommend saving all the separate parts and loading into your own installation. Just in case saving a factory file from one environment & loading into another causes issues.
For the record, I did the following:
Used the Separate Connected Surfaces function
Increased the size of each of the spokes by 1%
Ran the rim through 3D Builder to repair it.
Took 10 mins to diagnose & sort out! Think I've earned a coffee!
Posted: Fri Nov 30, 2018 11:40 am
by Peter_O
Thanks a lot guys! When in Hamburg, feel free to get in contact for a coffee. :)
Beeing a newbie in Fusion 360, I had done it as component with multiple bodys.
Following your advice, I joined the bodies before STL export now, leading to a reasonable slice:
Thx again!
