REGRESSION: Using linear advance on prusa i3 MK2 and wipe on retract causes blobbing
Posted: Sat Dec 01, 2018 6:46 pm
by ttn
As the title says, with 4.1.0 there is blobbing introduced if linear advance is enabled with retract on wipe enabled
Disable wipe on retract, the issues go away.
Disable linear advance, the issues go away.
Going back to version 4.0.1 also solves the issue meaning that this is a bug introduced in 4.1.0
I'm using the prusa i3 MK2 with stock firmare. Linear advance has been enabled using the gcode command M900 K30 as recommended by prusa.
FFF profile:
Prusa Research Original Prusa i3 MK2.fff
(11.82 KiB) Downloaded 131 times
