"Failed to create final toolpaths"
Posted: Sat Dec 22, 2018 1:34 pm
by mcamou
I moved from a Mac to Linux some months ago but hadn't opened Simplify3D yet. I opened Simplify3D (4.1.1) and imported my .fff profile previously exported from the Mac. I then imported a model, edited the process settings accordingly, and tried to slice ("Prepare to Print!"). I got a message in the message area at the bottom of the window: "Failed to create final toolpaths".
I am attaching my .factory file in case it is useful for debugging.
Any ideas?
Thanks!
Re: "Failed to create final toolpaths"
Posted: Sat Dec 22, 2018 1:48 pm
by mcamou
OK, after a bit of quality time with strace I found that I had a permissions error. $HOME/.local/share/Simplify3D was owned by root (so it seems that at some point I did start it up with sudo). I was having another problem with S3D not saving my settings between sessions, and it was also a permissions problem, this time in $HOME/.config/Simplify3D (adding this one for future Googlers)
Posted: Mon Mar 18, 2019 3:29 pm
by obertini
Thanks a lot! Your finding probably saved me hours of searching.
Posted: Fri Aug 02, 2019 2:50 pm
by tuxdata
Thank you. I was seeking for a while.!
Posted: Sun Jan 19, 2020 1:30 pm
by eric5093
Thank you, I just install Simplify on Ubuntu, and got this error on my 1st attempt to print. Saved me too
