Juliemac
Communications wait command
My printer does not use the command.
I have to reset that feature with each part I make. Is it possible to set the check box OFF when the software loads so I dont have to go to options/communications?
TIA!
Re: Communications wait command
1. Tools > Firmware Configuration
2. Make the desired change(s)
3. Export the firmware configuration
4. Edit process settings > G-Code Tab
5. Check the box to update the firmware configuration with this profile's use
6. Select your custom firmware from the firmware type dropdown
7. Click update profile or Save as new
