vandel212
Z-Axes out of sync
Thu Jan 10, 2019 10:28 pm
Hi, I have a Robo 3D R1+, and I'm using the default S3D profile for it. When I finish a print, I notice that my X Gantry is way out of level. The right side is visibly higher than the left side. So much so that it wont even auto-level on the next print. What that tells me is during the print, the Right z-axis is moving up faster than the left.
I do not believe this is a hardware issue, as when I use the Craftware slicer, it works properly (I tried the same model with both slicers). Is there a setting or something I need to adjust in Simplify3D to get this to print properly?
Re: Z-Axes out of sync
Fri Jan 11, 2019 10:00 am
Please attach your G-Code that is working, and then one from Simplify3D that is showing the issue when you try to run it.
vandel212
Fri Jan 11, 2019 11:36 am
S3D-Jake wrote: Please attach your G-Code that is working, and then one from Simplify3D that is showing the issue when you try to run it.
Sure thing, here you go. Thanks!
Z_Axis_gcode.zip
(1.94 MiB) Downloaded 13 times
vandel212
Sun Jan 13, 2019 4:47 pm
Does anyone have any thoughts on this? This issue basically makes it impossible for me to print anything, and I'm all out of ideas.
