Hi, I have a Robo 3D R1+, and I'm using the default S3D profile for it. When I finish a print, I notice that my X Gantry is way out of level. The right side is visibly higher than the left side. So much so that it wont even auto-level on the next print. What that tells me is during the print, the Right z-axis is moving up faster than the left.
I do not believe this is a hardware issue, as when I use the Craftware slicer, it works properly (I tried the same model with both slicers). Is there a setting or something I need to adjust in Simplify3D to get this to print properly?
