Jordan0090
Random supports generated
Mon Feb 04, 2019 8:11 pm
Hello,
My design doesn't have or need supports. When I put the part into Simplify 3D the preview looks correct but when I generate the print it has created random supports. I checked all the settings and can't find why the software is doing this.
S3D-Alex
Re: Random supports generated
Tue Feb 05, 2019 12:12 pm
It is possible you still have the Generate Support Material option turned on in the Support tab of the Process Settings. If this is not the case please post a Factory File showing the issue. Thank you!
Jordan0090
Sun Feb 10, 2019 10:26 pm
No. That was the first setting I checked. The printer is doing a simple large square then randomly a 45 degree angle has been added...
S3D-Alex
Mon Feb 11, 2019 10:54 am
Can you please post a Factory File showing the issue you describe?
