MontyFlange
Re: Support Separation from part not working as expected. Circular support generation is horrible.
Thu Feb 28, 2019 10:09 pm
Supports has gone really bad now, now top/next layer after the support looks like a lose stringed 12 string guitar . Any curved surface, forget it, nothing but a mess
FlashForge Creator Pro
Max Filament
Fri Mar 01, 2019 8:30 pm
Agreed.
I am considering buying a prusa m3 just to get the prusa slic3r, the supports on that are amazing.
Check it out. https://www.youtube.com/watch?v=5Luj3rlmbLk&t=332s
Mon Mar 04, 2019 6:31 am
How fine SUPPORT can be printed
You can see here!
The outside is excelent (0,12 mm layers) but the inside is not significant worse. What a bummer, I can't see it later, all watertide closed ;-)
H.
Outside of the model and the breakout of the support as ONE part exept the support inside of the the small tube, that must be broken when removing.
The underside of the holder-seat (for RAM) is not an issue, it has no bottom layers, only perimeters and infill!
