Change layer direction on bottom layer
Posted: Sat Feb 16, 2019 1:59 pm
by Faurholdt
Hello
I want to change the angle on the bottom layer to 45 degree lines instead of 90 degree lines
How is this done? Thanks.
It's shown in the attached picture :shock:
Re: Change layer direction on bottom layer
Posted: Fri Feb 22, 2019 1:19 pm
by gearsawe
Is this a raft layer, support layer, interior fill or exterior fill? they can all be be changed in each of there designated area. Look at infill and support tabs.
Posted: Fri Feb 22, 2019 6:32 pm
The infill showing in the screen print looks very much like the bottom layer of the printed part.
The "External Infill Angle" on the Infill tab has its first (or only) value set to either zero or 90. Changing the value to 45 will give you what you desire.
Posted: Sun Feb 24, 2019 6:46 am
by Faurholdt
Thank you for the replies. It is sorted out now. Time to print :P
