Need help with internal perimeters blobs!
Posted: Sun Mar 24, 2019 6:24 pm
Hi, having a little problem with Blobs on the inside of my perimeters. this is only happening on internal walls, and only with my PLA profile? (retraction is 0.5mm @40mms,costing @0.2mm direct drive, i3, 0.6mm nozzle, 0.3mm layer height)
Also, have another issue on the internal walls where they echo what's on the opposite side......maybe Thin Wall Behaviour setting?
Internal thin wall type = allow single extrusion fill
Allowed perimeter overlap = 20%
Ooze Control Behavior (ticked):
Only retract when crossing open space
Force retraction between layers
Perform retraction during wipe movement
Only wipe extruder for outer-most perimeters
Thank you for taking the time to read.
