Craftbot 3 starts grinding and tries to leave build area
Posted: Tue Mar 26, 2019 10:41 am
by grplr
Running a Craftbot 3. It has a feature called the Supervisor that monitors for filament jams. Yesterday I had the feature detect a jam and it couldn't clear it, so the print stopped. When I came home and checked, everything seemed good so I hit resume on the print, and the printer proceeded to be start the print over but it was offset by a few inches, and the printer started grinding and "bottomed" out in the y axis when trying to print, making some gnarly grinding noises.
It seemed as though the print didn't want to restart in the appropriate spot.
Re: Craftbot 3 starts grinding and tries to leave build area
Posted: Tue Mar 26, 2019 1:28 pm
by DarthRevan
Sounds like a firmware issue if after a firmware initiated pause the print begins again with the wrong offset. Have you reached out to the manufacturer for tips about offsets and firmware initiated pauses?
Posted: Thu Mar 28, 2019 4:46 pm
by grplr
No, I didn't reach out. I was sort of under the impression that S3D would have had some of this sorted out since the Craftbot 3 is listed as a supported printer. I have no issue reaching out but I feel I am not educated enough yet on this software since I have been relying on Craftware up to this point.
