Process that starts above bed has incorrect first layer infill
Posted: Wed Apr 10, 2019 10:34 am
by wfcook
In this factory file, the "bulb" process uses an incorrect infill angle on its first layer.
Re: Process that starts above bed has incorrect first layer infill
Posted: Wed Apr 10, 2019 11:37 am
I've looked at this factory.....
First thought....waste of time having one process to print one line at .15mm height, then second process to print remainder at 0.075. But this is only a comment!
The issue is that the second process starting "off" the bed is creating a bridging layer. The code change that makes this happen was applied in v4.1.0...pre-v4.1.0 and normal infill occurs.
If the angle is alli mportant...then applying a bridging infill angle will give a workaround....
