spilz
Brim doesn’t start by outside lines ...
Sun May 19, 2019 2:38 pm
Hello,
When I print 2 or more objects (I didn’t notice it for a single object but maybe it does it too), the print start by the inside line of the brim or the outside line of the piece (difficult to say), then print the outside lines of the brim.
I use brim for wrapping (I print ABS) of course, but like a skirt I expect it clean the nozzle and help the abs flow to be constant (during heating and homing some ABS melt and the flow is not good at the beginning)
Did you notice it too ?
Is it a bug ?
Or is there a setting I didn’t found to force the print to start by the output line of the brim ?
Thanks for your help
Re: Brim doesn’t start by outside lines ...
Sun May 19, 2019 4:32 pm
You can follow the print head movements when you switch in the Print Preview from Layer to Line and reduce the videos speed.
GER
spilz
Sun May 19, 2019 4:40 pm
Ok, but it shows what appends, but I can’t change / fix it
