Adventurer3 out of print range error
Posted: Sat Jun 08, 2019 2:54 pm
- Printer: Flashforge Adventurer 3 (Firmware 1.0.8)
- FlashPrint (Version 3.27.0 x64)
- Simplify3d Version 4.1.2
Printable (150x150x150mm) "* .g file" of object size more than half
FlashPrint issues "out of print range error".
Error when X or Y size exceeds 75 mm.
Z is no problem.
As a result of investigating "*. g file", it turned out that M118 of the 1st line is the cause.
It seems that the object size (X, Y, Z) is output to M118.
It seems that I have to output half the value of the object for X and Y size.
(Reference * .gx file output by FlashPrint)
(See below for example maxsize)
before: NG(output *.g by Simplify3d):
after:OK(edit *.g file):M118 X150.00 Y150.00 Z150.00 T0
The setting equivalent to this part is in Script-> StartScript-> TerminalCommand in "FFF Setting".M118 X75.00 Y75.00 Z150.00 T0
(See below)
I think that it can be solved if the values of build_size_x and build_size_y can be reduced to half, but is there any way to specify half of the values?{PREPEND "M118 X [build_size_x] Y [build_size_y] Z [build_size_z] T0 \ n"}
Thank you.
