Single Extrusion voids/bug
Posted: Fri Jun 14, 2019 3:29 pm
by PhillipM
Been trying to work out why my machine was having some issues with extruding single lines - I thought it was the extruder so stripped the machined and cleaned everything, etc, still had the issue with single extrusions being underextruded and not meeting the perimeters - couldn't work it out out, but I just loaded a new model and when previewing, I can see clearly on this one the problem, the extrusions are doing some weird stuff, any idea what's causing this?
Re: Single Extrusion voids/bug
Posted: Fri Jun 14, 2019 4:39 pm
There's nothing "Causing" what you are describing......because there's absolutely NOTHING wrong! A 0.4mm wide extrusion will not mysteriously expand to fill a gap that is 0.6mm wide! There will be a gap.
Reduce your number of perimeters down to 2 and increase the (Infill) Outline Overlap to say 80%.....and the slicer will have a chance of filling the non-multiple of extrusion width gap!
Posted: Fri Jun 14, 2019 5:03 pm
by PhillipM
Eh? It's a single extrusion that's causing the gap, you can see it's the correct width in half the points and not in others.
Works fine on other layers:
I'm not sure if it's just a rendering bug but it does seem to coincide with the models that have some issues with single extrusion fills.
Posted: Fri Jun 21, 2019 10:00 am
by S3D-Alex
Could you please post a Factory File where you see the gaps as represented in the first image?
Posted: Sun Jun 23, 2019 5:20 pm
by PhillipM
I can send one in, but I can't post it here publically as the model is commerical.
Posted: Fri Jun 28, 2019 10:54 am
by S3D-Alex
Thank you for sending this file. We were able to confirm this issue and have documented our findings for the Development team.
In the meantime as a workaround I would suggest increasing your perimeter overlap as this will eliminate the sections of Single Extrusions that were causing errors. Thank you again for your help finding and diagnosing this!
Posted: Wed Jul 03, 2019 11:32 am
by PhillipM
Great, unfortunately tolerances won't allow more overlap for this atm - the parts have to come out with less than a tenth of a mm size-wise to keep them on spec through temperature changes, so I'll have do a little jiggling with the sizes first.
I do have some more parts that show the same single infill issue if they need them to work from.
