Solve temperature overload problem
Posted: Sat Jul 13, 2019 12:53 am
by levithanh286
Hello guys,
I have the AZTEEG X3 Pro motherboard with 5 extruders that are liquid cooled running on RepRap thru Simplify 3D (not sure if that makes a difference with what I am dealing with). I have been having an error of the following that I can't figure out what's going.
READ: Error:Coolant temperature exceeds max, extruders switched off. MAXTEMP triggered !
I can't find anything as to what would cause this and fix it.
Suggestions?
I have tried contacting the manufacturer of the 3D printer and I think they are out of business now...
HELP!
I appreciate any suggestions... or even stabs in the dark at this point.
Re: Solve temperature overload problem
Posted: Mon Jul 15, 2019 10:43 am
by S3D-Jake
The error clearly identifies the issue is related to the temperature of the coolant.
I'd suggest you check your coolant temps and the sensors reading the coolant temps. If those are fine consider adjusting the coolant temperature threshold at which this error message and corresponding firmware initiated shutdown of the extruders is triggered.
