Suffsails
cooling fan preheat
Mon Jul 22, 2019 9:30 am
the cooling fans are turning on when preheating, this is new since the last update (all my previous files preheat ok)
S3D-Alex
Re: cooling fan preheat
Mon Jul 22, 2019 10:10 am
Could you please post a Factory File showing this behavior?
Suffsails
Mon Jul 22, 2019 10:39 am
these?
sufsailtt.stl
(1.64 MiB) Downloaded 6 times
GoPro_arm.factory
(14.43 KiB) Downloaded 7 times
Suffsails
Mon Jul 22, 2019 10:40 am
just had another simplify update so i'll try that - we have been manually toggling the fan off when preheating
S3D-Alex
Mon Jul 22, 2019 12:55 pm
Thanks for posting your Factory File! So currently your Cooling tab has two setpoints for 0 and 80 respectively. The issue is that both of your setpoints are currently at Layer 1. Since the software cannot make the fan be at both 0 and 80 percent simultaneously it defaults to the last value you set for that layer. Please let me know if you have any other questions!
