Clive
Build question
Fri Jul 26, 2019 9:57 am
I am trying to build a thinnish part of dimensions 5mm thick, 50mm wide and 80mm high, when I insert all the parameters that I want in printing with dual heads for supports the program builds an extra skirt around the part. At first I thought I might be for extra support because of the hight of the build. however is not attached to the build at all.
Can someone please advise me if this is correct of have I set something incorrectly in the program?
Clive
