Unable to Manually Remove Supports
Mon Aug 12, 2019 8:13 pm
In the picture as indicated by arrows are two "pockets" in my part that fill with supports.
I use Support Generation to add supports however I want to remove most of the supports in the pockets leaving only the rows closest to the "bright yellow" area.
I can not do this since there is solid material from the part above the supports. Second picture.
I know I can not generate supports but rather manually add them but on most pieces that is just not a good option when you really only need to remove a small number and since there can be numerous supports in other areas.
Is there any way to do this?
This has been an issue with S3D for a long time now.
Kyrian
Re: Unable to Manually Remove Supports
Thu Aug 29, 2019 4:21 pm
I have the same problem and the cross-sectional view does not solve the problem
S3D-Alex
Wed Sep 04, 2019 9:47 am
Could either of you please contact us at Support@simplify3d.com so we can look into this further and possibly recommend some next steps?
