kgiannelos
Can't get this stl to print as is
Mon Sep 09, 2019 5:58 am
I am trying to 3D pring an stl model I downloaded from MyMinifactory.com.
However, it seems that when generating the print preview in simplify3D, some of the borders of the print are not generated at all. I have attached the factory model as exported from simplify3D as well as the stl file I am trying to print. I have also attached a screenshot highlighting the issue in simplify3D Preview mode.
Any help would be appreciated, thank you!
music-from-the-heart-pendant-1.stl
(134.65 KiB) Downloaded 24 times
music-from-the-heart-pendant-1.factory
(35.99 KiB) Downloaded 20 times
TheBum
Re: Can't get this stl to print as is
Mon Sep 09, 2019 11:52 am
Probably not an optimized model. Many times, you can fix gaps like this by going into the Mesh menu and selecting "Separate connected surfaces".
Mon Sep 09, 2019 12:06 pm
My guess is that those areas (the walls) are too thin to print for your current configuration such as nozzle size or extrusion width.
Mon Sep 09, 2019 3:37 pm
Not a guess...….as TB says, advice how to cure the issue...…...use the Separate Connected Surfaces option on the Menu dropdown.
kgiannelos
Mon Sep 09, 2019 5:50 pm
Thank you guys! Separate Connected Surfaces did the trick, amazing.
