TeasleyPrint
Not applying bridging
Wed Oct 23, 2019 8:54 pm
Just started to play around with the bridging setting but cant get them to apply bridging setting to anything.
Da Vinci 1.0 Modified
XYZprinting Da Vinci 1.0 Pro.fff
(12.57 KiB) Downloaded 166 times
Re: Not applying bridging
Sat Oct 26, 2019 11:36 pm
Bridging will only be triggered over solid fill areas above gaps that meet the minimum area requirements. Please attach your factory file so more of a complete answer can be given.
ceondraka
Mon Nov 04, 2019 12:51 pm
I'm seeing this also on certain features where it's not calculating bridging.
I have a 18mm wide gap in a wall that is 4mm wide and the slot is 2mm tall (I'm thinking this is the issue with such a small valley under the bridge). I removed the suggested supports as the bridge area is 2mm above the surface so laying support material in there is a waste This is a slot in the wall for a ribbon cable to come out. (Raspberry Pi Case)
I have changed everything in the settings and this example will not bridge (no yellow coloring). Funny thing is...... it does print ok... not perfect and has a little sagging (I cut that strand out because the first cross has infill between the 2 inner/outer wall lines).
I also discovered another bug during this that I will post separately (Dense Supports will not print with Support Print every-2 layers is on and the first Dense support is between that layer number).
Mon Nov 04, 2019 1:22 pm
The same request as above...….please attach a factory file.
Its impossible to give advice when you know almost nothing about the model and the settings you are trying!!
ceondraka
Mon Nov 04, 2019 3:20 pm
Will do when I get home. Don't have access to the files on the road.
ceondraka
Mon Nov 04, 2019 6:33 pm
Ok.... Got it to work had to drop the unsupported area threashold way down to 35 and now it's calculating and inserting bridging. Will try print tonight to see if it changes the result.
Tue Nov 05, 2019 5:09 am
Glad you're sorted.....
