Re: Quality problem, mini stairs along z axis
Fri Nov 01, 2019 12:32 pm
... I want to try it out later, actually the Mankati is running with a 12 hours print (ABS clear, up to now at halftime nearly perfect) and I'm sorry, the A8 has loaded at the moment very expensiv filament ( > 50 € / 500 gr.), not recommendable to play with.
H.
DzzD
Sat Nov 02, 2019 1:53 pm
Ok back after further tests, some observations :
Problem appear with retractions, but blob are not where retractation take place, they are rather where retractation lands.
Indeed my goal is not to print a simple cube, I could achieve a nearly perfect one by simply disable retractation, but rather print a piece with retractation without any blob, so that I will be able to print several parts together with nice finish, or print multi-materials without blobs artifacts.
For now the best solution I have found is to set 3 perimeters (with only 2 perimeters it still renders thoses little stairs), with inside-outside direction. This way blobs are far less visibles but still not perfect...
I will continu to investigate and will give some more feedbacks. If someone find another or better solution pleeease share it.
Sat Nov 02, 2019 2:29 pm
I have print a lot of tests , but with my standard settings I could not reproduce your issues.
The picture shows an ensemble of 3 small cubes (print stopped by 5 mm) , will say the print has position changes between the models with retracts ( ... Only when crossing open spaces)
Material ABS, 230°, bed 90°
Perimeters 3, Infill 25%
Speed ~ 50 mm/s
EW 0,50 mm
Layer height 0.10, 0.20, 0.25 mm what are 20%, 40% and 50% EW : LH
No problems to perceive.
H.
DzzD
Mon Nov 04, 2019 8:12 am
Thanks for your time !
I finally end to the conclusion that 3 perimeters are required when EW/LH ratio gets high, this is not a big constraint and give a lot better results.
I can finally print my cube :) !
