UberEgo
S3D Slices w/ Voids
Thu Nov 07, 2019 9:38 pm
I'm not sure why simplify is generating voids on this model which slices fine in cura...
Same layer settings -- and even if I use all the defaults, it does the same.
clip_seperate_2.stl
(55.84 KiB) Downloaded 23 times
Re: S3D Slices w/ Voids
Fri Nov 08, 2019 9:23 am
Use the Separate Connected Surfaces option on the Mesh dropdown to split the two meshes out of the .stl into separate models. The part will slice correctly after you do this.
UberEgo
Fri Nov 08, 2019 12:22 pm
Ty! That fixed it.
Seems counterintuitive to "separate" in order to "join" :)
