ice0tea
can't connect USB / Wifi to 3D printer
Sat Nov 23, 2019 3:55 am
I am using Flux Delta 3D printer (where SIMPLIFY3D software support), and I find there is no port available in "machine control panel" page, how can I connect my printer via USB port?
Furthermore, this printer supports WiFi connection, does SIMPLIFY3D support connection via WiFi?
Regards,
Ice0Tea
blinktbi
Re: can't connect USB / Wifi to 3D printer
Wed Jan 08, 2020 3:22 pm
Did you ever receive a reply to this question? I am having the same problem with my printer.
New ZMorph VX 3D Printer, Laser cutting and etching and CNC.
S3D-Alex
Thu Jan 09, 2020 8:44 am
The ability to connect via USB or WiFi is dictated by the printer you are using. Could you let me know what machine you are trying to connect to as well as if the USB connection shows up in the Ports drop-down of the Machine Control Panel?
ice0tea
Thu Mar 19, 2020 7:08 am
I am using Flux Delta+ printer (https://flux3dp.com/delta-plus/)
I find there is no port selection in machine control panel of Simplify3D software, however, I can connect it with manufacturer's software (Flux Studio) via bundled USB adapter.
BTW, this is also wifi enabled printer, how can I config Simplify3D software from network?
