Thin walls not Infilling and Top Layers not sealing
Posted: Mon Nov 25, 2019 3:02 pm
1) Have tried various Advanced setting changes to improve thin wall printing with no visible change.
2) Profile attached.
3) Print image attached.
4) Machine Specifications::
Windows 7 Home Premium 64 Bit
SeeMeCNC Rostock MAX v2 latest Arm, Carriage, and Hot End upgrades
EZRstruder Upgrade
HE280 Hot End
Nozzle ID stamped: 0.5mm
Simplify 3D v4.0.1
Rambo Firmware Repetier 091S
24 Volt 20 Ampere Main Power Supply
Switching Buck Converter to supply Rambo 12 Volt power
6mm thick 6061-T6 Aluminum Build Platform
300 Watt 24 Volt Silicone Round Heater Pad
Solid State Relay to control Heater Pad 24 Volt from Rambo Build Platform Heater Output
Kapton Build Surface
Q: Any suggestions for Settings to change for improved print Top Layer sealing?
EZRstruder Upgrade
HE280 Hot End
Simplify 3D v4.0.1
