ritgrad83
First layer running parallel to support walls - bridging
Fri Dec 20, 2019 1:27 pm
I am noticing that whenever I used support for a recessed feature on part being printed the first layer is printed in parallel to support walls causing some lines to droop between supports and leaving a wiry finish. How can I set the gcode to print first layer across supports where optimum bridging can be achieved?
