joost
Unselected models print
Mon Dec 30, 2019 11:07 am
When I have two or more models in the model list (left upper), and have one or some selected, they all do print - even the unselected models. If that is intended behavior, I do not understand what the select/unselect box is for.
airscapes
Re: Unselected models print
Mon Dec 30, 2019 12:07 pm
That is the intended behavior. That just hides the model, not real useful.
You need to open the process and on the bottom of the first tab is a button to select the model, all are selected by default, only select the models you want to print.
