Milestone85
How to change initial starting purge (nozzle wipe?)
Wed Sep 10, 2014 8:34 pm
How would i go about changing how when a print starts the extruder purges (or pushes out) out so much filament. Now it is squirting a big line of filament just off the side of the bed, then the nozzle moves to the print table and cleans the filament off. Before it used to go to the corner of the print bed, push out a big blob, then quickly clean it off as it slid across the bed. Id like it to go back to this method, i find the current method where it extrudes a long bit of filament and then swipes over the bed to be troublesome, sometimes the filament will not fall off the tip, it get stuck to it then ends up on the print model at the starting layers.
adamcooks
Re: How to change initial starting purge (nozzle wipe?)
Wed Sep 17, 2014 2:54 pm
Did you ever find which line of gcode was doing that? i have a larger then my heated bed glass plate and the purge is causing some difficulties.
nxumdon
Wed Sep 17, 2014 3:45 pm
Can you post your starting gcode...this will probably show the issue.
Thanks
KC_703
Sat Sep 20, 2014 4:22 pm
Could this be machine specific?
My Printrbot Simple Metal doesn't perform the starting purge/wipe. So I added a startup script to print a few lines of filament after the auto-level procedure.
I've read that this is a normal function of Ultimaker machines... so possible a recent firmware affected what you're experiencing?
dsegel
Tue Sep 30, 2014 5:39 pm
Could you share the code you use to print those first few lines? I'm running into the same problem myself (also with a Simple Metal) and was thinking of doing something similar.
adamcooks
Tue Oct 07, 2014 2:40 am
theres a line in the start gcode that calls for priming
mine says "G4 P3500 ; purge nozzle" i just put a semi colon in front of it and it stopped that
dsegel
Tue Oct 07, 2014 1:47 pm
"G4 P3500" just makes it wait and do nothing for 3.5 seconds before continuing. It doesn't actually extrude or retract anything. I suppose if you had a large amount of ooze it would let it happen.
KeyboardWarrior
Wed Oct 08, 2014 9:27 am
adamcooks wrote:theres a line in the start gcode that calls for priming
If you wanted to extrude 35 mm of plastic (which is a lot), it would be G1 E35 F225
I would recommend purging about 15 mm of plastic, G1 E15 F225
F225 is pretty slow, but I'm not extremely familiar with the PrintrBot's extrusion rates, so 225 is pretty safe.
TenKOhms
Wed Oct 08, 2014 10:35 am
Like KeyboardWarrior said, the G1 E15 F225 will do an initial 15mm extrusion of filament if you put it in the starting G-Code. For PrintrBot Simple, or printers with an auto-bed leveling probe, I would suggest this for a starting G-Code Script to home, probe, and purge correctly:
G28 X0 Y0 ; home X and Y axis
G29 ; initiate z-probing
G1 X0 Y0 Z.10 ; move to corner of bed
G92 E0
G1 E15 F225
G92 E0
gelly
Sat Dec 13, 2014 7:37 pm
how can i purge both extruders and not just one ? what is the code that selects the active extruder ? so i may be able to add that into the starting gcode script ?
thanks
