I upgraded to 2.1.2
Now the HBP setting seems to be ignored.
I have it set to 65 degree but it prints as no heat applied.....
I have a flash forge creator and never had a problem but now it does not register the temp I set for the HBP.
I can run older files I created off the SD and it works great.
I even changed the temp a few degrees in my latest print to see if that would work.
No help.
Basically it will not put the HBP temp in the gcode...
any ideas... older versions work just fine....
does the new software version have an issue?
I tried in repG and makerware and it works fine
help?????
