Billzilla wrote:The printer is starting the print off the far right-hand end of the platform and does that no matter if the object is placed in software in the centre or far LH end of the platform.
I really need to start using this printer so what's the solution ... ?
Attached are photos of where I put the object in the software and where it started to print on the platform.
If you're using Sailfish, it could easily be EEPROM parameters, the toolhead offsets look to be off.
Edit: Plugged in my FlashForge and opened up Replicator G-40 Sailfish Edition
http://www.thingiverse.com/thing:32084
The x toolhead offset for me is zero, my theory is that yours probably has a value of 20 or 25 mm, which would explain why your prints are off-centered.
